LIAN LI ROG DYNAMIC XL SIDE PANEL
2 Jul 2007
Cheshire East
Well had a disaster today, I removed the side panel to do some stuff in my case, I have done this hundreds of times with out issue until to day, when I put it back in position i put the roof back on as normal and then i could hear a creaking sound and this happened in front of my eyes
wilmington nc lunch specials
I have managed to remove it in almost one piece but now I need a new side panel, anyone know if I can get a replacement
ouch
got the same case
though very unfortunate for you
its good to see it doesnt shatter all over the place
you can buy replacement side panels
have seen ones without the black border before
not sure what uk retailers will have one though as think
the ones i saw were somewhere in europe
ask ocuk?
email lian li?
edit
is the case under warranty?
may be worth a try too
I managed to remove it by sticking cello tape all over it and it came out all most in one piece so managed to avoid all the glass getting everywhere but there was still minute pieces of glass on my desk which i found in my hands (the blood gave it away lol) so if it does happen be aware. Really weird thing as it was making a cracking noise for a good 10 minutes till i got it off the case. Its in a blanket now ready to go in the bin lol
Looks good though :) contact Lian-Li I'm sure they will help, put it on twitter that way people will see it and may quicker to get a replacement.
update for those who may be interested.....managed to source a replacement from a well known online store from China. Cost me £47 inc delivery, the actual cost of the panel was £14. Estimated delivery is 15 days ;)
There's the normal one
With the black border and seen one with no black border
Even the one with the border
If you have a led strip in the bottom the borders not wide enough
I used vinyl to widen mine to stop being dazzled
By the leds
The no border looks good if no led strips
Guess you'll find out in couple weeks lol
an update for those who may be interested, having contacted Byron@lian-li via email I have now got a replacement side panel which arrived today, so all is good. ;)
I had to cancel the original order from the online store after they informed me they had run out of stock
Thanks Byron
Only used lian li support once
Was a very positive experience must say
Good to see that wasn't a one off
Mind if I ask how much they charged
Or if you managed to get it under warranty
warranty ran out in April...so paid £42 including delivery which to be honest is well worth it. At least I can sell the case on now as I bought a thermaltake view 51 because I did not know if I was going to get anything sorted but as it happens there was no worries.
I am loving the new case btw...it looks awesome
That's very reasonable to be fair
Packaging and delivery on a glass panel
Probably isn't cheap
And getting it under warranty would have been
A long shot anyway
Since they have no idea if glass failed
Or was a user accident
