so tldr they are witholding stock to keep prices artificially high, gotcha
That is a stupid take. They are not stopping anyone buying. They are not dropping prices.
I disagree, they've already made large improvements to RT performance with RDNA3, the performance is not that much behind the RTX 4000 series.
I also think that to most gamers, rasterization is more important than ray tracing. RT is not considered to be necessary, but to most gamers, smooth frates are.
They need a much improved fabrication process in order to reduce the high power consumption of RDNA3, so that they can scale the number of compute units beyond 100.
People pay £1000+ for a 7000XTX with it's 96 CU's, so a whole console with a 100+ CU's for £600 is good value and I think a lot of people would scoop it up (it would probably appeal to a lot of frustrated PC gamers who can't afford the crazy prices AMD and Nvidia are charging for new GPU's).Well, £550 is a lot for a console.
I wonder how many would be willing to pay for a console with an MSRP of £600?
This is not really true. Had it nicely summed up in some imgs but imgur **** the bed & I can't link 'em, so for now you'll have to visit TPU yourself.I disagree, they've already made large improvements to RT performance with RDNA3, the performance is not that much behind the RTX 4000 series.
This is also not accurate. One, because Nvidia vastly outsells AMD. Two, we know from devs on consoles (in this cases 70% of) people purposefully go to turn to 30 fps mode for better IQ than keep 60 fps, even when it defaults to 60 fps mode, in a shooter (I also think that to most gamers, rasterization is more important than ray tracing. RT is not considered to be necessary to most gamers, but smooth frates are.
FSR 3 can't help AMD with anything because it only exists in their imagination for now. You can't tell me what a technology that doesn't exist will help with when you don't know how it performs.Additionally, frame generation (via FSR3) can help AMD to achieve decent frame rates, when RT is enabled at 1440p and 4K.
They need a lot of things but performance first of all. If they can't compete with Nvidia in performance then no one cares what their efficiency is.They need a much improved fabrication process in order to reduce the high power consumption of RDNA3, so that they can scale the number of compute units beyond 100.
That's not the same as choosing between RT on and RT off.Two, we know from devs on consoles (in this cases 70% of) people purposefully go to turn to 30 fps mode for better IQ than keep 60 fps, even when it defaults to 60 fps mode, in a shooter ().
dropping to 30 fps for better iq? ******* gross, why not just sync them to blinking for even better performance instead of making the games run well and at a decent fpsThat's not the same as choosing between RT on and RT off.
They are specifically talking about adjusting the resolution, at the expense of framerate. There are cases where I might consider doing that too, but probably not in a first person shooter.
Nvidia has been outselling AMD since well before the RTX 2000 series, when RT was introduced.
At 4K with RT enabled, the RX 7900 XTX is 'just' 16% behind the RTX 4080, and keeps up with the RTX 3090 TI.
The RX 7900 XT offers similar RT performance at 4K to the RTX 3090.
Sure, you can buy a RTX 4090 and get ~55% better performance with RT on, but AMD isn't competing with a card that has an MSRP of £1,579.
As for FSR3 (which they have confirmed is definitely coming), I think they will get similar results to Nvidia's frame generation.
Scaling up the CU count beyond RDNA3 I think makes sense, because that will mean a scaling up of RT cores also.
According to the chart you posted:I disagree, they've already made large improvements to RT performance with RDNA3, the performance is not that much behind the RTX 4000 series.
