I'm looking into setting up an alarm system in a new build for a family member.
They have alarm cable all run through the house, and it would be nice to have a reliable wired setup seeing as all the cables have been run, but it seems many of the newer modern systems are all wireless.
It's a shame, as they're the ones with the better apps and integrations, but they have the downside of needing to replace batteries and be prone to jamming.
Systems that seem easy enough to buy and fit yourself seem to be Ring and Ajax systems.
Ring has the benefit of being rather cheap to buy into, but I also view it as a bit of a cheap brand. The doorbells are okay, but the cameras are a bit poor. However they do have the fact that their backend is Amazon, which bodes well for longevity, updates and overall reliability, plus the app is probably pretty decent compared to incumbents such as Texecom etc.
Ajax systems seem very slick, with a polished app and decent customisability, but sensors are pricey and I feel their outdoor siren is not ideal for a home environment. Ideally the alarm system should deter before attempted entry and there's no option for an always on light for the ajax outdoor siren as far as I can tell, even though you can plug it into the mains and and it does have LEDs for various status levels built in.
Their support tells me the siren firmware can't be updated for security reasons, so it's unlikely to ever be added unless there's a hardware revision.
Ring on the other hand has an excellent dusk till dawn light on their outdoor siren, but it also has the tacky blue ring branding on it (IMO).
They icon choices on the Ajax keypad seem poor to me too. They seem quite unintuitive, at least the Texecom keypad in the place I'm stay at the moment has a display that can show text and actual words on the buttons, which is much easier for someone less tech savvy to use.
Ajax does have a wired fibra system rolling out, but you need to be trained on it before they'll sell it to you, so it seems a bit more specialist, so I imagine between the hardware and extra install cost it might end up being a bit cost prohibitive for a home install purely for the sake of using the existing wiring.
I'd rather get a system that I can buy, install and configure myself so we don't have ongoing support or maintenance costs to a 3rd party company if we don't really require it.
Are there any other brands/systems that should be considered these days?
Anyone have particularly good or bad experience with either Ring or Ajax alarms?
Any other considerations that people have when installing a modern system?
