- 9 May 2022
- northumberland
So recently bought a 4090 phantom from overclockers I currently have a 5800X3D is it worth the cost to upgrade to a 7800X3D at 2560x1440/3440x1440 resolution
The OP also has a 4090 so it is perfectly relevant to him.![]()
AMD Ryzen 7 7800X3D vs. 5800X3D, Zen 3 or Zen 4 3D V-Cache, Which Should You Buy?
Australia, Cloud III: https://www.amazon.com.au/dp/B0C3BV19Q3New Zealand, Cloud III: https://www.mightyape.co.nz/product/hyperx-cloud-iii-gaming-headset-bl...youtu.be
They used a 4090 though, so just bear that in mind.
I suspect overall you be hard to tell the difference actually playingSo recently bought a 4090 phantom from overclockers I currently have a 5800X3D is it worth the cost to upgrade to a 7800X3D at 2560x1440/3440x1440 resolution
