Ive got the internal scribe cracked for the internal angles but Ive watched a few videos for the external corners and there is a mix of people just cutting them at 45 and others doing it properly and using an adjustable bevel to get the exact angle.
Does it just depend on how far out the walls are? I assume if its only very slightly out then 45 degrees and some caulk/filler could be a acceptable bodge for a DIYer? They will be painted over once installed
Any advice for a novice appreciated thanks.
