- 4 Aug 2007
- Wilds of suffolk
Someone has posted on here before about panels on sheds I don't recall the hate then, just quite a few people wanting details of the inverter, batteries etc (it was a standalone setup)
We have people here (ronski and bugone) who have self fitted panels onto rooves, a flat roof is not much better than a shed in my experience if its not in good condition. Both of them I would suggest are likely to have done a decent inspection first I am sure but if they specifically followed the same level of screw penetration in to beams as a "proper" installer only they know.
Saying that, have a look on youtube into what some installers will do and leave. Like missing when drilling through the roof tiles and securing in effect in air...
Its actually my biggest concern with solar, that a poor install could become lethal. As a homeowner you somewhat "safe" if you have used a reputable installer. DIY though and its always possible someone could come after you for a negligent and lethal install.
Sheds (like flat rooves) are more susceptible to rot than a normal roof. As long as the shed is sound its probably got less chance of being an issue than a house, due to height.
I would personally after having watched some videos go inbuilt next time, if that was my main roof or a shed etc. They just use gaskets between the panels and trims etc that give redundancy to ingress, sure they are a little more expensive, but look nice.
For a shed they would actually IMO make the shed less likely to try to have the roof lifted off due to the added weight and nothing for the wind to directly try to get under.
