Solar panels and battery - any real world recommendations?
It's just for the longevity of the AC coupled inverter. I can see the temperature - and it's never goen above 60c, but with the fan it keeps it under 50. My main production inverters are mounted under the panels - not much I can do to cool them.
I'd have thought production hit is more about the panel getting hot, and less efficient, than the inverter.
yeh my inverter is currently showing 55 degrees..... which is pretty hot to be fair lol
Depends how much power is uses, how much it costs and where it deposits it's heat.
Seems a bit overkill for what a small fan could easily accomplish.
If I lived in a rental with space to add some external panels - then something like this could be pretty useful to help lower bills. Not sure how much you'd get from a pair of small panels mounted at an inefficient angle on a balcony though. It's rather pricey - so I doubt you'd ever see a meaningful ROI.
Not sure about the electrical safety/legality aspect. Electrical fires in towerblocks are pretty harmless anyway. :o
Yeah they have been brought up before.
Its hard to work out exactly how they work, but it appears you need to plug in special plugs for anything that you want to use from the literature.
Edit, in regards using power when there is grid outage I mean.
There is a minimum you don't need to report in regards solar installs in the UK, its something like 900w.
That's not how it looks though -
DrBUKfk.mp4
not everything is how it looks, but having seen a video of how it works, it doesnt go in via the plug......this system has been discussed before
Pretty sure it is.
The smart plugs monitor demand instead of a CT around the meter tails. The charger socket must also have power going in as well as receiving it for the system to function.
Discussed, but not actually explained - in fact the last time you "explained" it, @Bug One seemed to be left just as confused
Edit:
Manual is here: https://websiteoss.ecoflow.com/cms/...erter User Manual V1.1 (EN)_1686293304065.pdf
and seems to show it connected only via plug (the app shows options to prioritise either prioritizing power supply or power storage)
Edit:
Manual is here: https://websiteoss.ecoflow.com/cms/upload/2023/6/9/EcoFlow PowerStream Microinverter User Manual V1.1 (EN)_1686293304065.pdf
but i showed you a picture of the grey box on the wall....thats a micro inverter, so its doing the same thing as the inverter in your attic or the enphase micro inverters on panels. Its also a special charging socket and plug, that links to your fuse panel
i mean your current inverter is connected to the grid via an ac cable into your fuse panel. This is connecting the microinverter to a special ac plug and cable, via an ac socket to your fuse panel.
Whats the difference???
I can see a grey box on the wall - in fact have some more pictures of it
Where in their documentation is this mentioned, or are you just assuming? A special socket is not mentioned, nor any special connection to the fuse box, beyond that provided by a normal socket.
I don't have a current inverter or solar at home, hence the interest in such a diy option, that as apparently advertised doesn't need an electrician to install
The cable goes direct from the AC OUTPUT in the above picture, into a standard wall socket? There is no special connection to my fuse box beyond the standard ring main back to the fuse box???
From the little time I've spend looking at this so far, below 800w doesn't require you to notify the DNO.
The inverter turns off during an outage, to prevent backfeeding and the potential risk to the DNO if they aren't expecting power to be there e.g. when doing maintenance.
no assumptions being made...the documents call it a micro inverter....thats needed to turn the dc from the panels to ac for the battery and other ac outlets. Thats what inverters do.
The documents also ref smart plugs, they could be just standard smart plugs, but who knows, but they are ref: multiple times in the sections.
Even if it is connecting to standard ac socket in your wall....in a way thats the same as a solar inverter in the attic, but that would have its own fuse within your panel. if it is a plug and play option, then yes no special wiring is required. I would just question why it needs smart plugs and what smart plugs it requires
It's not just a micro inverter though. It's a small, but fully functional smart hybrid inverter. Connected to a standard, existing 3 pin socket.
Ahh - something I've just found. Systems under 800w are exempt from G98. That might be why they show 800w as the maximum you can set the output to in app.
