Hi, looking for some advice on a new PC build I am buying.
I am aiming for something pretty quiet with good all round performance after a basic CPU overclock.
I will be using it for general purpose PC tasks including 45MP photo/4K video editing, web browsing, a few games like Forza/GTA, serving 4K movies to my TV. I won't be upgrading it for several years except storage drives.
Spec so far -
Intel i7 13700KF
Nvidia RTX 4070 12Gb
32GB DDR5
Z790 Mobo
CPU Cooler AIO 2x140 Fan
M2 SSD for System+Apps
16/18Tb HDD for storage
Fractal Design Meshify 2 Case
700w PSU
For the CPU Cooler its definately going to be a AIO 2x140, but not sure which one. Being quiet is top priority, then price. Just doing a basic CPU overclock so I assume performance will be good enough with anything.
I might want to run the pump only and no fans for general web surfing/idling, with the fans only switching on at higher loads.
I saw one with the pump in the water block instead of on the CPU, does that matter much ? What probably makes the most difference will be the software, I want good control over the fans and pump and monitoring of temps etc. Reviews often don't go into detail on the software much so thought I'd ask here what's the best ? Do people try to buy the Mobo+Cooler from the same company for better software compatibility ? Don't care about looks.
Also not sure what heatsink compound to use, but don't want to mess with liquid metals. Is ARCTIC MX-4 ok ?
Considering these -
Alphacool Core Ocean T38
be quiet! Pure Loop 280
Corsair iCUE H115i PRO XT RGB Liquid CPU Cooler 280mm
ARCTIC Liquid Freezer II 280
MSI MAG CORELIQUID C280
Spec so far -
Intel i7 13700KF
32GB DDR5
Z790 Mobo
700w PSU
Considering these -
