Chances of 4 x 16GB dual rank DIMMs working with 5800X3D?
12 Jan 2010
I have a 5800X3D running on a MSI MPG B550 Gaming Edge motherboard with two 16GB sticks of Corsair Vengeance RGB Pro Black running at 3600 CL18. According to CPU-Z the part number is CMW32GX4M2Z3600C18 and they are dual rank DIMMs.
The PC is running perfectly and I have no real need for 64GB RAM and the sensible call here is to not mess around and stick with what I've got.
However!
If I get another identical kit what are the chances of the 5800X3D being able to run 4 DIMMs a) at all and b) at full speed?
Should be able to run all 4 dimns but you may not get to 3600mhz and mite have to settle for slightly lower speed if problems occur.
5800X3D according to AMD supports the following Memory configurations and speed
System Memory Type = DDR4
Memory Channels = 2
Max Memory Speed
2x1R = DDR4-3200
2x2R = DDR4-3200
4x1R = DDR4-2933
4x2R = DDR4-2667
From experience its really not worth the hassle of getting them stable.
You'll probably end up losing performance on the the 32Gb you use for the extra 32Gb that you will not use.
I got 4 sticks and cant run more than 2733mhz, must be a mobo limitation since i had same limit with my 1700, 5600x, 5800x and 5900x
@RatmanGB
Obviously not quite the same setup but I'm running 4x32GB sticks with a 5950x on an msi b550 mortar matx board and they're happy at 3600mhz... I started with 2 and then added 2 more, I literally just turned on xmp, adjusted infinity fabric to 1800mhz and it all just happily ticked away. They're working fine at 3600mhz even after I tweaked CO/PBO too....
Obviously mileage will vary with the x3D versus my 5950x but it 'should' work imo.
Ram used: Corsair Vengeance LPX - CMK64GX4M2D3600C18
No issues running 4x 16GB sticks of Corsair Dominator Platinum at 3200Mhz (16-18-18-36) with a 5800X3D, originally it ran with a 5950X and had no issues on that chip either.
Model is the CMT32GX4M2C3200C16
Sorry, I've tried to find out via Google but haven't been able to - are those single or dual rank?
Thanks.
Thanks.
They are dual rank.
