DDR4 or DDR5 Mobo's?
16 Apr 2010
Hi All,
Thinking of buying an MSI Z790 mobo but unsure whether to go for a DDR4 or DDR5 version. Would my DDR4 memory be compatible in a DDR5 mobo?
Cheers
Daz
If building a new pc then DDR5 all the way and AMD would be my choice for the ability to drop a new cpu in the board a couple of years down the line. DDR4 will not work in a DDR5 motherboard.
budget for new mobo and cpu would be £600. Gaming (Star Citizen, Elite Dangerous). GPU is RTX 2070 with no plans of changing. Hope that helps. Resolution of 1920 x 1200. Not 4K.
I already have a Corsair Hydro water cooler and memory. It's 32GB (CMK32GX4M2D3200C16).
Oh, an easy decision then (if you're going Z790) :D
My basket at OcUK:
Total: £612.97 (includes delivery: £7.99)​
Otherwise, I'd have suggested:
My basket at OcUK:
Total: £592.96 (includes delivery: £7.99)​
With this cooler.
FYI: it makes more of a difference at 1080p than 4K, but with decent DDR4 the difference is generally pretty small, so unless you're a competitive gamer I wouldn't worry.
£390 (incl. VAT)
£315 (incl. VAT)
£240 (incl. VAT)
£210 (incl. VAT)
FREE DELIVERY
£145 (incl. VAT)
£140 (incl. VAT)
