Deleted User 298457
Deleted User 298457
Aye but brakes are cheaper than clutches.I normally go down through the gears if I am coming up to a stop/roundabout etc. I rarely even brake unless I am caught napping. If you are planning way ahead you shouldn't even really need to use the brake pedal. Likewise when going forward I will get to speed as quickly as possible just using 1st and 2nd then settle for a gear while cruising.
It is pretty much exactly the same when driving a lorry but instead of downshifting we use what is called an exhaust brake which simulates the same thing. It strangles the engine to reduce speed in the same way whilst also downshifting at the same time. You do it right you do not even touch the brakes at all and go through the roundabout smoothly or come up to set of lights at crawl.
