FSR vs DLSS vs XESS!! Which Upscaler is Best and When to Use Each One
JOIN THE DISCORD!https://discord.gg/xbVEkhPJ72Link to Spreadsheet if you want a closer look at the performance numbers:https://docs.google.com/spreadsheets/d...youtu.be
Xess is better than fsr in some situations. Also why didnt you watch the video if you want answers to you question?
I was just wondering if it brought AMD back into closer contention in upscaling if it worked better than FSR (like DLSS). The Asus cashback deals on the 79s has me tempted.
Aren't all the cashback deals finished? I think the GPU cashback ended on the 24th of June, and the rate my gear cashback ended at the end of June?
Thanks. What was the conclusion?
you really need to watch that video i linked to, it shows it all in detail. you will understand when you see the side by side comparisons and zoom ins.Ok, interesting. Thanks for the replies. DLSS is still king then.
FSR and DLSS offer the biggest and most similar performance benefits.
XESS offers less performance, but often higher quality visuals than FSR.
XESS and FSR quality differences are game dependent, but DLSS always wins.
FSR performs similarly on everything.
XESS performs significantly worse on non-Intel GPUs.
Conclusion:
Intel: use XESS, but check if FSR offers higher performance
NVIDIA: use DLSS
AMD: use FSR, but check if XESS offers better visuals
I was playing around with settings in Witcher 3 and XeSS looked pretty smooth. I'm not sure if that's an indication of advances in the software or placebo on my behalf? There's no FSR3 option to compare to on this game, only FSR2 which is also pretty good.
It was awhile ago I watched it, but I think Witcher was the main game that he said had better visuals versus FSR.
