USB C Wall Power Supply - DELL Inspiro 5570, i7 8550U
20 Sep 2005
Wilderness of ESSEX
Hello All,
can you please suggest what is a good power pack for USB C charging which also has 1 or 2 USB ports ?
It is to power DELL Inspiro 5570 LapTop whcih I believe is at least 45w power draw.
many thanks
T
What capacity are you after?
These will do 60W (with a certified PD cable) from the USB Type-C port (also got Type A ports as well). Available in most good fishing tackle shops as well as online. Not got a massive footprint either & also have a 42K mAH version as well.
I use them when fishing tbh & get a good few charges of M2 12.9" iPad Pro & iPhone 14 Plus from it (as well as charging other low current items I also have with me). They don't use the cheap 'reject' cells like a lot of the cheaper ones do which are stated as being a certain capacity/output but are in reality 1/10th of the stated amount.
Hi,
sorry I need to edit my question, though what have just mention is pretty good information.
I am after a new Wall power Supply USB C !
Hi,
No worries. Saw "Power Pack" & that is what springs to mind automatically now. I am old school & still call what you are looking for a "Charger" lol. TBH I don't think you can go far wrong with any of the big name USB-C wall chargers. I am sure Ugreen or Anker will have something that should fit your needs.
I have my Ugreen 65w charger for over a year now and it's been good to me.
Ugreen 65W USB C Wall Charger Plug - 4 Ports - Ugreen
Hi,
can you use your laptop with the Upgreen plug in, i.e does charge while operating the laptop ! ?
Strange question, because my LapTop also needs a new battery so the Charger will have to power the LapTop while I using it ?
T
Hi,
T
I don't have any laptop with USB-C chargers, I use the charger to charge other things, so I can't comment on this.
I'd imagine it would work just like a standard 65w laptop charger does and you can use the laptop while it's charging up. But I believe that it's healthier for the battery not to use the laptop while being charged up.
