Could be a fan rubbing against a wire.What I have noticed is that it has a grinding sound more than a high-pitched noise only when it hit the max core clock. It is a bit annoying as it boosts to the max core clock when out of NPC or vendors menus for a few seconds till the core drops as I run it in power management mode normal.
out of question as it does only when gpu clocks are maxed.Could be a fan rubbing against a wire.
Fan bearing? May only do it at max clocks as that is when the fans spin up most. Trying sticking your finger on the centre of each fan to stop it (when you've reproduced the noise) to see it that's the grinding.out of question as it does only when gpu clocks are maxed.
the fans don't spin when it does the grind sound. It does it regardless of whether the fans are spinning or not.Fan bearing? May only do it at max clocks as that is when the fans spin up most. Trying sticking your finger on the centre of each fan to stop it (when you've reproduced the noise) to see it that's the grinding.
I've had this on both graphics card fans (Gainward) and case fans (Silentwings, Coolermaster) in the past.
RMA it coil whine is not acceptable. Send it back for a replacement.that's how it sounds.
Dropbox
www.dropbox.com
And i can hear it from 10m away.
Is there any Gigabyte rep on forums?
