Hedge ungains. Love it. Dad has a petrol long arm beast, but then that's to tackle 100ft of 15ft high, 10ft wide leylandii. Note to future self: don't move anywhere with these and never plant them.
i use a titan from screw fix .. 3m ext to keep the neighbours greens out of my garden ..
I've got a non extending version and it's been excellent, i've been amazed at it's power. It'll go through some really thick branches without any fuss at all.
mine seems to last forever with a 5ah battery as well.
I dont get the hate for it? Easy to cut and acts as a good barrier between houses
If it has been well maintained over the years it is fine and can even look nice like yours. If left unmanaged for a few years it can turn into a nightmare.
My neighbour has huge leylandii which they have never touched and the former owners of my house also never bothered to maintain our side. I have been working on trying to chop some of it back but it is so tall the branches overhang my garden by about 15 - 20 feet!
Here is just a small part at the bottom my garden that I have been working on. It looks a mess and will always look a mess until the day she decides to chop them down, unfortunately she seems to have no interest in doing that
www.leylandii.com
How do you find the cutting performance as compared to say mains corded?Arrived a couple of days ago and I just spent five minutes trimming the top of a hedge down and tidying the front off a bit. This would normally take me at least half an hour to do and involve me perching precariously on a small stepladder whilst struggling to reach far back enough at the top.
Literally five minutes trimming did the same job. It'll need more doing but I'll leave that until later in the year, this is enough for the midsummer trim. When I do it again later, I'll take at least another foot off the top and trim the front back a long way as well.
I didn't even need to use the additional extension pole, the trimmer and the handle was enough. Yes, it is significantly heavier than the small trimmer I've used before but the shoulder strap really helps that and even with my weak arm, it's perfectly usable.
Ouch. Done that once fell through a hedge into next doors garden.I just got me a Flymo version of the same, have a beech tree out front that I like to keep in the shape of a willy, shh don't tell the neighbours. However I fell off my ladder last year pruning it and nearly did myself a serious injury but lucky I managed to fall onto a hedge instead of the pavement.
They're quite heavy beasts, and the flymo doesn't have a strap, but are so much quicker to use as you've stated..
I used it for five minutes to trim a light bush. It’s easily as good as the cheap £40 corded from B&Q. I also used it to cut through quite a woody branch that the cheap corded one couldn’t cut.How do you find the cutting performance as compared to say mains corded?
