Get the Thermalright contact frame its' way cheaper and does the same.Thx guys, not sure i can fit a 420, because of back fan, will check, do either of you use the Thermal Grizzly contact frame ? cheers
You got the overclockers link to the exact contact frame, thxGet the Thermalright contact frame its' way cheaper and does the same.
Definitely worth it.
looks good, there are so many aio's to chouse from, still not sure what to get.I run a Deepcool LT720 on my [email protected] atm and been really happy with it, I run it in the roof too.
Unfortunately Overclockers don't sell the Thermalright contact frame.You got the overclockers link to the exact contact frame, thx
Yeh i not ever used one either, did you use a contact frame also ?I put an Arctic Freezer II 360 in the top of mine yesterday. First time I've used an aio, installation was easy.
Ah I'm not on intel, 5800x3d here, sorry.Yeh i not ever used one either, did you use a contact frame also ?
If not the 280mm are just as good.Yeh i just got to hope it will fit at top of my Lian Li Lancool III case, with the Asus ROG Strix Z790-H Gaming WIFI motherboard, as this motherboard has a big vrm cooler it seems.
