AMD 6-core Ryzen 5 7500F debuts without integrated graphics
5 Aug 2017
Cornwall
Affordable AM5?
Essentially a cheaper 7600 without the graphics isn't it. Could be a good seller
Yes, and can OC as per the reviews 5.6GHz+ looks easy.
$179
So £140+VAT (168)
£169.99 UK retail ish.
Not too bad really as the 3600 ($199/£189 release price) was around that money for a good amount of time.
$179
So £140+VAT (168)
Yep. Still rocking the 3600 here. Was thinking of eventually moving over to the 7600. Maybe it'll be the 7500f if the pricing is right
Not even attempted to OC, just purely ran at stock.
Just running all core at 4.2GHz with a undervolt will benefit you. The boosting pushes the voltage to around 1.35V out the box. You shouldn't have an issue setting 1.25V and 42X multi. Run a R23 test now and one after to see the performance bump and temp drop!
That's right, that was an undervolt and OC lol. Default is 4.2GHz boost not all core and uses around 1.35V ish to do so.
Great. You are with the times. Run my R7 5700X at 1.109 and upto 4.25Ghz, run at 39C-40C mostly and upto about 62C-65C under load and on air whilst generally under 66W on boost. I can bosst clocks (if I up the volts to about 1.2v) but haven't needed to as yet
Sounds good. I think this 7500F will be a fun CPU to tweak. One of the reviews state 5.6GHz was easy so that's the same single core as a 7900x out the box. Couple that with the new bios updates for higher memory speeds and it should be a monster of a 6 core.
I think it is only available in China and maybe Indonesia at the moment. However, JD.com does have it on there website according to tech news and that it will be released to the rest of the world in short order so you can hopefully look to get it on OCUK at that point
Be nice for around Black Friday, they'll be giving DDR5 away by then lol. Already "Crucial 16GB (1x16GB) 4800MHz CL40 DDR5 Desktop Memory" JDEC spec is £21.99 a stick. Two Fat ladies for 64GB, perfect for a workstation if speed isn't a consideration.
Readily available in China for shipping to the UK, under £160 with VAT for a tray version.
Fingers crossed OCUK source some tray stock to sell?
