LG C2 owners.. Weird update
12 Apr 2007
My C2 forced to accept a deep colour HD enhanced BS.. And now everything is over saturated and I can't figure out how to turn it off or roll back the update... There's no options in the menu system..
Any ideas?
Any ideas?
If your sources support deep colour (4k HDR) then you should enable deep colour.
What are you picture settings maybe you have colour and contrast too high ?
Thanks, sources are PC and 4k firestick but I run the PC at 1440p..
I just want to turn it of, it was fine before and now it looks terrible.
Maybe I can do a factory reset on the TV?
You'll want to use pc mode for the desktop input
I
Is there a way to stop the LG OLEDs from asking you to update the firmware every time you start it up? I have mine already set to do not check for updates, or whatever it is, yet every time I turn on I have to select no, do not update. It's annoying. I don't know what the firmware update has yet without reading up on it so don't know if I want it.
