How to best move my Windows install?
15 Aug 2012
Thanks to a system refresh (new mobo, RAM and CPU) I have added an NVME to my PC.
I currently have Win 10 on a SATA SSD (500GB) and have just got a 1TB NVME which is were I'd like to have my install. What's the best way of doing this? I've thought about cloning the drive but then potentially have the issue of needing to resize the partition.
I'm thinking I might have to just bite the bullet and do a fresh install with a USB install drive, change the boot order so I boot from the NVME and then wipe the SATA?
Macrium Reflect (the free version is discontinued but is still kicking around) or any other modern disk cloning tool will handle this and allow you to expand the partition to fill the new drive.
Thanks. They offer a free trial and did both the clone and expand partition in one go. Amazing how easy it was!
Before:
After:
Thought it was still free
Until 1st January 2024?
Even then suspect they may just stop you updating
Rather than disable everyone's free version
Especially if you just block it in firewall
This thread is timed to perfection. Just picked up a replacement drive and want to move my windows drive to a larger SSD I currently have a 250Gig and simply want to clone that drive to a new 1TB SSD. Macrium Reflect preferred way to go? Or are there any other ways that are free and simple?
Cloning is pretty much pain free these days. If its an old install thats seen many major updates, driver updates etc I usually use an OS drive change as an excuse to do a fresh install.
Cheers. Looks like there is a combined version of Magician & Migration software, but they also have stand alone versions. I'll download it and have a little look.
Thanks. I’mgetting some Bluetooth issues probably caused from going from using a dongle to a new mobo with built in so I think I’m going to upgrade to Win 11 and then do a fresh install.
Worth going into device manager - show hidden devices and delete anything that's no longer relevant
Reboot and then hopefully might improve things
Cocked up my disk clone!! Any help appreciated...
So old system disk is a 250Gig Samsung 840 new Drive is 1 TB 870. Downloaded Macrium Reflect V7. Ran it up, no issues, sees both disks so I clone old disk to new target disk and off it goes no problem. Only issue is as I guess the clue is in the name, it's done a "clone" of the first drive to the new drive and left me with a 750Gig unallocated partition... Doh.. ( just ignorance on my part with not doing it before really. I just assumed it would use all the space.) What I wanted was to use all the available space so in essence Just end up with a new "C-Drive"
Looking in Disk Manager
I've now got a 3 partition a 250Gig, 750Gig which I can't suss how to re-merge as a single partition!? And and Recovery partition clone that I cant shift on what was my pristine 1TB.
So how do I
1 undue/fix the ****-up
2 Force it to use all the available space.
Cheers
So how do I
Cheers
I think you should be able to delete the empty 750GB one and once it reads as unallocated, expand the smaller one.
I'm pretty sure you can tell Macrium Reflect to expand the new Windows partition so you use all the space on the new drive.
Here is a guide how to it here: https://www.macrium.com/blog/cloning-a-disk-with-macrium-reflect-v8
Thank you for that, I'm just having a read through it now. Bit annoyed with myself as I just assumed instead of properly reading up on it first.
That is what I thought. But if I do that and try to create a "simple volume" it throws an error message " There is not enough available space on the disk to complete the operation" does that regardless of whether I choose the unallocated 200 odd or 720 odd.
Scratching my head a bit?
Macrium will be EOL on 1st Jan. I'll still use it, not like my home pc is getting audited and will fail anything for having EOL software :D
If my machine become infected, i'll clone from a backup image and uninstall Macrium!
I'm still using Office 2007, works fine - though I do use O365 aswell
Macrium Reflect Patch Details
Macrium Reflect Free - Service Announcement
This is to notify that Macrium Reflect Free Edition is being retired. Security patches will be provided until 1st January 2024, but there are no planned feature changes or non security related updates following this update.
