I had my eye on him going around the roundabout and he forced me out of lane.That road layout is not great I can see what they were thinking and your own approach was less than ideal.
Clearly his fault!
Considering you were the one left driving through the hatched markings to get into your lane I can 100% understand why he wondered WTH you were up to. If that's the correct way to use that roundabout it's impressively bad.
Yeah it looks like a very "unnatural" lane layout so the obvious way to use it isn't the way the lanes are telling you to.
Both the drivers are in the wrong tbh, this is the roundabout in question:
Google Maps
Find local businesses, view maps and get driving directions in Google Maps.www.google.com
Neither of the drivers made the effort to start moving left towards the exit, the poster of the dashcam video is especially in the wrong since he took so long to start moving to the left.
No you are wrong because I had him checked in my wing mirror and he made no attempt to move over forcing me into the checked area.
Your entitled to your opinion I guessAre you sure you posted the right video?
He looks to be about three car lengths in front at the point you should have been moving left, he wasn't forcing you to do anything
I'm just confused by you saying you had him checked in your wingmirror (implying behind you) but he's clearly way in front of you, it sounds like you're describing a different incident to the one in the video
Ok I give up lol. Do you see the black car sandwiched between the lorry and the silver offender? that is the correct route to take on this roundabout and thats the end of the discussion as far as i'm concerned. No harm done, no accident because I am a defensive driver.
Maybe this guy will break check the wrong person in future and get a lamping.
I can see what the correct route to take would be, I can't see that he's forced you to do anything though, he was far enough in front that you could have continued to take the correct path rather than hugging the kerb like the pickup in front of you did. He'd have ended up in front of you (which would obviously be wrong on his part) but there was no need for you to go driving through the hatched area or anything really - you could have just maintained speed and watched him go in front rather than speed up a bit so you could get on the horn and make a point.
That would be a merge in turn roundabout lol
This one from Stoke-on-Trent this week going north on A500, car undertakes me and then cuts in front giving me the finger.
You was too over to the right. You even went over the hatch markings. You were not following the lines on your nearside. From 21 seconds on you were in completely the wrong position. You were in the right lane initially but stayed far too right as if you were going to loop round and go back up the A50 instead of onto the A500.
You can use both right and second from right lane to get on the A500 but the second from right has a second merge further up the road to join the A500 (This is where most people panic as they think they are in the wrong lane and heading towards the A5006) whereas the lane you are in takes you directly onto the A500. The van most likely thought you were going all the way around back up the A50 towards Derby because your positioning was all wrong.
The lorry was a complete numpty though as he forced the Mercedes over and couldn't even be bothered to indicate that he was changing lanes.
Y, I think he had already taken my lane without realising it, fault of the poor markings and layout of the roundabout I guess.
Don't think it was worth brake checking me though? or is that acceptable on here?
