- 29 Dec 2009
Veeam community edition agent works with TrueNAS CIFS/SMB for sure. Assuming you've whitelisted the IP for CIFS/SMB access?
Never assume anything where I'm concerned!Veeam community edition agent works with TrueNAS CIFS/SMB for sure. Assuming you've whitelisted the IP for CIFS/SMB access?
I’ve been using Paragon Community edition for years after the built in Windows Backup failed me.
Pretty sure it can backup to network locations. It’s pretty much set and forget.
Free Data Recovery software | Paragon Backup & Recovery Community Edition
Reliable backup and recovery tool for windows 10 with advanced options of restoring files, folders and os. Incremental and differential backup of the whole system.www.paragon-software.com
Robocopy then
(Somewhat in Jest, but also not - because our software/servers, and backup needs at work are so bespoke - I ended up writing something in VB6 to pull files into the correct places, and then just backup at different intervals with scheduled tasks that run robocopy)
A combination of full logical daily backups of MySQL (mysqlbackup piped directly to GZip to compress ~200gb to ~15gb), that then have to be matched with binary log files for each day (that are flushed at 5 minute intervals), whilst also pulling in a copy of an MDB file at 6 hour intervals.Ooof sounds messy. Curious what your bespoke requirements are though.
