Man of Honour
- 23 Mar 2011
- West Side
Thanks, but I'm put off by it being only 100Hz. Is this something I shouldn't worry too much about with Freesync?
/edit - I see this one doesn't support Freesync. I'd looked at the AOC 27" one for £199, but £70 is a decent chunk of saving by going for the 1080p option and that will ensure the GPU stays relevant for a long time as well. Decisions....
If your graphics card is capable of 144fps (depending on game)which equates to 144mhz then the game will be slightly smoother than 100mhz but would you notice is the question.
Freesync and adaptive sync are virtually the same..
Its head bash for sure monitor choose.
1440p looks better on a 27" screen
Take a look at AOC Q27G2E/BK
But check reviews.
