6 Aug 2023 at 13:53 #21 CaNsA CaNsA Associate Joined 7 Jan 2012 Posts 2,016 Location Liverpool OnlyAlex said: But then how would you control the RGB or fan modes? Click to expand... Ai suite for the fans https://openrgb.org/ for the rgb
6 Aug 2023 at 14:16 #22 hyperseven hyperseven Soldato Joined 1 May 2013 Posts 10,059 Location M28 OnlyAlex said: How did you remove them? Click to expand... I have just disabled them for the interim to see if they have any knock-on effects if not will remove via 'sc delete' command.
6 Aug 2023 at 19:04 #23 OnlyAlex OnlyAlex Associate OP Joined 2 Jul 2021 Posts 256 Location United Kingdom hyperseven said: I have just disabled them for the interim to see if they have any knock-on effects if not will remove via 'sc delete' command. Click to expand... Ahh ok, fair enough. I've found ASUS cert service but no ASUS com service in task manager on my device. Not sure what the ASUS com service is anyway.
