GPU Hot spot temps too high on 6800XT?
27 Sep 2020
Hi,
Im looking for some advice on my GPU. I have never really had any issues with it, but I have been playing through the campaign of CoD:Modern Warfare II during last few days. The fans have been quite loud but this is not unusual when playing fairly demanding games, and not sure that the Gigabyte gaming OC model has the best of coolers on it. I play on a 3440 x 1440p ultrawide. The CPU is cooled with an NZXT AIO and temps are great, and there is also plenty of airflow in the case.
What was unusual is that I have been experiencing quite a few crashes in the game where the screen goes black, the fans drop down and i have to hard reset the PC.
Id noticed that the GPU utilisation had been at 99% which I guess might not be that unusual but because of the crashes I decided to run HW Monitor so I can check the GPU temps.
GPU Temperature
Min:- 39C
Max:- 79C
Average:- 70C
Memory Junction
Min:- 42C
Max:- 76C
Average:- 68C
GPU Hot Spot Temp
Min:- 42C
Max:- 109C
Average:- 95C
The GPU Temp and Memory Junction don't seem too concerning, but the the Hot Spot Temp hitting close to 110C seems very high. I know this will be the hottest part of the card, but even so this seems quite high, and I wondered whether this was contributing to the crashing.
Has anyone noticed extremely high temps on this card, either generally or whether this might be an issue with this game only. I've never had any game crashes running games like Cyberpunk, Hogwarts, etc.
You think its worth a repaste of the GPU... I already have a tube of Thermal Grizzly Kryonaut so I dont have to buy any, but will this have little impact?
Thanks
GPU utilization @ 99% is good - it means your CPU isn't bottlenecking your GPU.
I don't have a 6800XT myself but according to Gamers Nexus' review, they do seem to run pretty hot (although that 109° does seem extreme).
110c I believe is the max temp for the hot spot, at this temp it should in theory throttle back but it could be crashing - have you tried an under volt on the card or is it still at stock?
Had the 6800XT GamingOC for a short time, found it to be v good. Hotspot is a little high though, think mine had like a 12/13c delta between edge and hotspot. I'd just tweak the settings/undervolt so it never reaches the 110c point (where the card starts to throttle).
Its just at stock. I see a lot about overvolting GPU/CPU but its not something I've tried. I'll maybe lookup a guide..
Not overvolting, undervolting. Slightly lowering the volts can actually be seen to show performance increases as lower volts = lower temps = longer/higher boost performance (to put it in its most basic form)
Well worth having a look at some YouTube guides and may well fix your problem.
Yeh did this with my 6700 on the weekend (re undervolt / overclock).
Found an easy to follow guide with a Google search. And in Adrenalin, it was very easy to do, especially so as the GUI is very user-friendly.
3DMark score went up with a small, but nice improvement and the card is now rated as "Great" rather than "Good" (guess I was on the cusp anyway but it made for good reading!).
Had a couple of crashes now in Diablo 4 to which I wouldn't have thought was particularly GPU intensive. Hotspot temp wasnt quite 110 C though, at this time max was about 105C. I'll find some Youtube guides on undervolting in the Adrenalin software to see if it sorts the potential problem.
Trying to think if any other configurations have changed on my PC but nothing significant springs to mind....only recent non gaming software I installed was Rainmeter to customise my desktop. I had used it previously though and dont recall any crashing.
Will go down the undervolting route, and might just repaste the GPU anyway, figure it cant do any harm.
On my 6800 I just did -50mv first and that was solid. Haven't done the rest yet but will be taking 25 mv off at a time until I feel it's enough or it crashes and then I'll just add a little more back and test. Plenty of good tests out there if you google.
Repasting normally always lowers temps if done right but its just the warranty stuff. Most are ok with it though.
Yeah, if you have to remove security stickers to get it off, leave it alone. I've seen some shocking results when I've removed coolers before, missing thermal pads, only partly covered dies, ram etc
By all means try some under volting. However the difference between the max hot spot and the max normal temp is quite large. That normally means the thermal paste has degraded. I think it’s time to re paste the card. If it’s still under warranty you might be able to RMA if you don’t feel comfortable doing it.
Ok thanks for all the inputs, really appreciate it. I'll try the undervolt first and assess my options from there depending on the result.
I have repasted a card before so fairly comfortable with doing that. I did it with the 2080 that I had previously and temps dropped by about 5 degrees if I recall.
Before this, I will also investigate potentially RMA the card too with Gigabyte. I only purchased the card last July, so seems a little early for paste to have degraded.
ultimately if it's unstable at stock you could argue it's a valid rma already but given it only takes a few minutes to try an undervolt there's no harm and might save the hassle of an rma. certainly though if it looked like it was still crashing after an undervolt and the gpu is determined to be the cause, i'd rma'ing before repasting. you could go to the lengths of repasting and still have the same issue but now you've potentially screwed the warranty.
anyways, get that bugger uv'd and let us know how you get on - i'm betting on it working fine (fingerscrossedemoji) :)
Thanks, will get to some testing tomorrow and let you know. Quick question, what do you guys use for stress testing GPU’s? I have a 3D mark license to use Timespy, etc. Are there any other good options?
Furmark will get those temps skyrocketing in seconds. Don’t run it for more than 10 minutes.
Ok, so I undervolted the GPP from 1150 to 1050 mV, which caused crashing when running Timespy and Timespy extreme. I raised this to 1080 which seems to be more stable.
Furmark seems to have the hotspot now hitting 105C but my last run at Timespy Extreme the hotspot in HW monitor peaked at 111C, so thats a 30C variance between hotspot and standard GPU Temp at 81C.
So im not sure where I am now....seems like i should contact Gigabyte to look at RMA
