OK first let's spam some pics then I'll go back over the post and give context.
Started testing the Lynx as i do before I work on any console that is sent to me and some things of note, it wouldn't at all work on batteries, so I connected the battery terminals to my bench supply and she is getting very hot and drawing 2 amps... thats wrong, cant get it to boot at all from battery terminals, I'm told it will boot eventually on the AC adapter so next i jerry rig the AC side and finally get it to boot once. But only once in probably 50 attempts... Lets pick up following the testing...
Right so opened her up and immediately this is what we have, a dc jack massacre. The jack is the incorrect jack and is glued to the board with 3 wires running from the jack down a via to the through hole pads below. more on this later as it comes back to bite us... Anyway....
This is the screws holding it together. Two original screws missing...
The parts to rebuild power circuit so we may as well start here...
Main fet, we will replace this:
And this transistor:
This resistor
the zenner:
And this bad last transistor here:
Eventually we will also remove this and a load of other parts but first lets rebuild the power circuit and see if we can't get it booting and reading games consistently first!
Power circuit removed...
New power circuit installed
And this is where it gets interesting, fired it up, same issue, so decided to investigate further. First things first, the lynx power circuit is almost the same as the game gear and fundamentally there is a switch in the dc jack that when you insert the jack it disconnects the battery circuit so you don't get the batteries getting power when the AC is connected because you will almost certainly have a bad time anyway the glue blocked the switch but also the jack was wired up wrong so the switch was effectively on the wrong side of the jack. I'll try and find a schematic so I can explain better. Anyway removed it all the glue and the bodge wires and soldered some wires directly to the Lynx jack side and success, she boots first time every time.
This is probably the worst screen ive ever seen on a lynx, there is something wrong with the resistor array that feeds the contrast wheel which means its only settings are bright and stupidly bright but that's fine because im going to rip out and disconnect the contrast wheel from its resistors and wire the mod directly to the pot you will see what I mean later. Really all we needed to do first is get it working and booting consistently, now we have that we can get the parts we need and continue with our mod.
This is where we leave it tonight, we need a new proper DC jack, not some bodge. Then once we have the new jack in we can test the battery side etc, make sure it isn't drawing crazy amps... fwiw those amps seem to go directly to the suzy co-processor (suzy is a sprite co-processor that can do crazy things with sprites, properly ahead of its time I might add and leagues ahead of say the game gear in terms of capability) she also isn't easily available so we really don't want to be frying her. we really want to fix this issue before we move on with the mod
