Currently run 240 KZXT -- temps are great on the 3600... Idle is about 37c and full load on cinebench 70c maximum ( and thats with all the fans turned down )
Considering upgrading my AIO to one with a fancier screen so I can see my temps easily and for better cable management.
I am siding with a 240mm because a 360mm would mean pipes obstruct the front of my side/front fans AND an extra fan on the top right would mean blocking some of the fan on the top right of my picture
So for performance 360 is better, but for aesthetics I am sure another 240 would be the safest bet? Also in regards for futureproofing what would you recommend ?
Any ideas ?
Thanks
Any ideas ?
Thanks
