- 14 Jul 2005
- Birmingham
To give you a flat surface to paint black, to hide the skirting you've removed, and to mount a new chimney vent to.What’s the reason for the ply behind?
yea i would because i've only ever seen a fire surround bolted to the wall in showrooms. in order for it to not look daft you really need the opening in place.Would you really![]()
this is the proper way to do it. the way your suggesting is just silly. but obviously that's just my opinion.I think we’re both right, upon closer inspection a lot of the pictures we’ve used as reference do have the hole opened........
The proper way to do it is to have an actual working fire place. Anything other than a working fire is a variant of a decorative item. Therefore it is irrelevant whether there is a hole or not.yea i would because i've only ever seen a fire surround bolted to the wall in showrooms. in order for it to not look daft you really need the opening in place.
Well yes, but if going for the decorative look, having an opening, imo, looks far better than just the surround bolted to a flat wall.The proper way to do it is to have an actual working fire place. Anything other than a working fire is a variant of a decorative item. Therefore it is irrelevant whether there is a hole or not.
You've saidWell yes, but if going for the decorative look, having an opening, imo, looks far better than just the surround bolted to a flat wall.
i have yea and i see you have managed to shoe horn your usual pointless post in.You've said
They don’t appear to go anywhere. They’re more like massive holes in the breeze blocks. I can stick my finger in and hit more breeze block, it’s not like it goes all the way up. Reckon expanding foam is forceful enough to break the blocks more?The holes will be for ventilation perhaps although rather poorly done as it doesn't directly connected with the flue
Why would you use expanding foam in there for breaking breeze blocks?They don’t appear to go anywhere. They’re more like massive holes in the breeze blocks. I can stick my finger in and hit more breeze block, it’s not like it goes all the way up. Reckon expanding foam is forceful enough to break the blocks more?
Expanding foam will expand into free space, it won’t really displace anything of any substance.Reckon expanding foam is forceful enough to break the blocks more?
No it’s not my intention to break them more. I was just checking it’s not forceful enough to do so, since some areas around the holes are really crumbly.Why would you use expanding foam in there for breaking breeze blocks?
We are total idiots here. Please do elaborate?Bed it on mortar?
Make some muck up, slop it down, then whack your stone on it. Jiggle it and done.We are total idiots here. Please do elaborate?![]()
So this type of stuff I guess? https://www.wickes.co.uk/Wickes-Mix-in-the-Tub-Mortar-Mix---5kg/p/154060You can get mix in the bucket mortar which'll be fine.
