I managed to route mine out of the way of the nvme heatsink on my board and down under the PCI-Ex slot, obviously, you have gone a bit further off fo the reservation with your build than I did so it looks like you have oooodles of space under the slot to run the pipes which would probably mean you could drop the rad a bit and still have the rad caps higher than the CPU block.
