- 31 Jan 2012
- Droitwich, UK
I'm using a 64GB model of the original Quest that I've borrowed from my brother. It's worked perfectly fine via AirLink with my VodaFone router and connection for several months, but since changing provider to a Gigabit one with a new router I have a crippling issue where within about 5 minutes of connection using AirLink it becomes a complete slideshow.
It doesn't matter whether I'm in game, Steam VR or in the AirLink Home area, the same thing occurs. If I turn my head the visible area is black until what should be within my FOV slowly rotates around and catches up. It's sluggish beyond belief and completely unusable.
If I reconnect my PC and headset to the Vodafone router (the net connection is presently still active) all is fine. If AirLink didn't work at all with the new router then I' have more to go on, but the fact it's fine initially is confusing.
Any suggestions? I've tried reinstalling the software on the PC to no avail, and reconnecting and disconnecting both PC and headset to the router and resetting the latter.
