- 14 Jul 2013
- UK
Hi all!
I noticed my Asus 3080 TUF OC 12GB hitting the temp limit in GPUZ. On further investigation highest GPU temp is 75*c, but I have a hotspot temp of 105*c!
I have an overclocking profile set in Afterburner to undervolt the card to 0.950v and have custom fan curve for the fans to hit 100% at 50*c. Also tried the card at total stock with same temp results but lower bench scores.
Should I be worried about a hotspot at 105*c? I guess this explain the temp limit even though I have a GPU temp of 75*c?
I miss my 1080Ti, such a good card for it's time.
Edti: Spec in sig. I also have 1x 140mm exhaust fan and 3x 120mm intake fans. They run at 100% when my CPU reaches 50*c. So general cooling shouldn't be an issue.
Edit 2: the card is just over 1 year old.
