I'm content with my build.
3 May 2012
Wetherspoons
Gotta say, very lucky really.
Current build:
AMD 5800x
64GB Corsair LPX 1.35v 3600mhz (2x32)
Sapphire Pulse 7900xt
MSI MAG Tomahawk X570
ADATA 2TB SX8200 nvme SSD
Samsung 1TB SATA SSD
Gigabyte G27Q 1400p 144hz
Corsair HX850 (yes probably 12/13 years old)
NZXT 360mm AIO
Lian Li o11 Dynamic
Ducky One 3 full size classic white blue switches
****** razor mouse (next to be replaced)
System is also working perfectly, stable, runs great. Other than the mouse and honestly doesn't bother me much, the system is perfect I have no desire to upgrade anything, and I reckon now this will do me for at least the next 3-5 years, maybe longer.
Please feel free to post your build and what you like about it, what you would like to change about it.
For mine......
Ryzen 7900 non X
32gb G.Skill Trident Z5 7800mhz running at 7400mhz CL32 1.4v
At the moment I have an ASRock Phantom Gaming D 6800, great chip, undervolts by miles, but im waiting to see real life what the 7800XT brings and if its worth changing.
ASUS X670e Gene........(its the only board I liked out of the X670 range that didnt look like a 1970s dishwasher.)
WD SN850X 1TB, WD SN850 1TB. Crucial P5 2TB all nvme drivers, not had a sata in years.
Be Quiet Straight Power 11 1000w Platinum PSU
Custom Water Cooling
Benq EX3501R 1440p 100hz 35" Ultrawide
Lian Li 011 Mini Air
Cherry MX10.0N RGB Keyboard
Razer Basilisk Ultimate mouse (brought from MM, nothing wrong with my Roccat, just fancied a change)
And yes I will probably change the board and CPU next gen in hope it fixes some of the issues, otherwise just the CPU.
Pretty much exactly what I have but a 12GB 3080.
My original intention was to get a 3080 but I left it out on my original build (November 2020) and thought I'd wait 6 months as maybe prices would go down.........
Ended up with a 3070 but imo that card is a lemon, a 3080 on the other hand I'd be more than fine with today.
Intel Core i5 12600
MSI Z690 Edge Wifi DDR4
2x 8Gb Teamgroup Dark Pro 8Pack Ripped edition 3600mhz C14
Gigabyte RTX3070 Vision OC
2021 Corsair RM850x
Samsung 970 Evo Plus 2Tb NVME
Adata XPG Gammix S70 Blade 1Tb NVME
Thermalright Peerless Assassin PA120 SE
Self built case set into my desk with 4x 200mm fans running at a silent 600rpm.
Dell S2716DG 27" 2560x1440 Gsync screen.
This was pretty much a compromise pc and at the time of building was fully water cooled. It's primarily a 1440p 144hz gaming pc. The 12600 was the first non K verion cpu that I had ever bought and I must say that it's done me proud and coped easily with everything I have asked of it. The thought was at the time to buy it as a stopgap and then upgrade to a 13700k in a couple of years time but that idea has been knocked on the head now and if any upgrade does happen down the line it will be to a 14700k but not anytime soon. Maybe when they start to pop up in the MM in a couple of years time.
The graphics card was bought from here in one of Gibbo's forum only deals back in the gpu shortages and cost a eye watering £600, way above what I would normally pay. The thing is I tied myself to Nvidia years ago by going for a Dell Gsync monitor with a proper Gsync module in it so it doesn't do Freesync and I am not willing to abandon the excellent Gsync it has. A swap to AMD would also mean a new monitor so makes that option even more expensive initially. I do really like this monitor and the gpu is a great match for it and even if it is only a 8Gb card it has given me zero problems with the games I play.
The thing I am most impressed about with this rig is the cooler. As I said previously, when built the pc had high end custom watercooling with a pair of Black Ice Nemesis GTX280 radiators, two of the best radiators available with 4x Arctic P14 fans in push/pull on each of them running at a silent 780rpm. After over 17 years of watercooling I made the choice to ditch it due to maintenance issues and the complexity of my setup (over 10m of tubing/12mm copper pipe and a huge rad box mounted in a window sucking in outside air). It wasn't a easy choice as my temps had always been ultra low with water temp rarely going above the mid 20's and down to single figures in winter but I bit the bullet and did some research on air coolers. I am a Cornishman so am tight when it comes to money which ruled out ridiculous priced fans and coolers. I wanted bang for buck so when I found some reviews of the Thermalright Peerless Assassin PA120 SE I started hunting for UK stock and found it on Amazon for a cracking price (it's even cheaper now) and went for the ARGB version. I had used Thermalright coolers back in the early Athlon days so knew that they were good. It was simple to fit, not overly large and looks good. I set the profile to silent mode in the bios and haven't touched it since. The 12600 maxxes out in the 48-50 degrees C range when gaming and even in the hot spell we had only hit 55 degrees C without the fans ramping up so they remain silent. I was so impressed with the fans that came with the cooler that I bought a additional 3 pack for less than £15 and fitted a extra fan to the rear of the cooler. It only dropped the temps a degree or two but probably helped keep the temps low during the hot spell without ramping the fans up. It truly is a impressive cooler.
With my choice to go back to air that meant sticking the stock cooler back on the GPU which I knew was a decent cooler as I tested it thoroughly before putting a water block on it. One thing I was curious about though was the backplate is all metal but does not contact any hot spots on the card so was purely there for the look. This has know changed. When putting the cooler back on I used Thermal Grizzly Kryonaut on the GPU die and swapped the stock thermal pads to Gelid Extreme pads. One thing I always noticed was that the rear of the card where the GPU die is always ran pretty warm and I wanted to do something about this. I had measured the space between the card and backplate and got Gelid Extreme thermal pads of the correct thickness. I stuck one on the rear of the GPU die so that any heat will be passed to the metal backplate. This has worked a treat and the backplate is now doing something other than looking good. It gets pretty warm now but being right in the centre of the airflow from the front and rear left hand 200mm fans the heat gets dumped out of the case pretty quickly. Another thing I noticed due to going back to air was that the NVME drives were getting cooked even though they had heatsinks fitted. This was purely down to the GPU so I decided to do something about this as well. I bought a Kolink ( :eek:) pci-e 4.0 riser card as it was the cheapest on here. It's actually pretty well built and decent quality and works perfectly. The next part of my plan was to make a shroud for the GPU to sit horizontally in so the fans face up. This was easily made out of some old case panel I had lying around and the riser card fitted to the left hand side. it stops any heat going down on the motherboard or drives and due to it's location between the front and rear 200mm fans any heat is quickly carried out of the case. Weirdly it dropped GPU temps as well and in normal gaming the GPU tops out in the low to mid 50's. The hottest I have seen was 62 degrees in the hot spell and the fans only ramped up to 75%. They don't even run at 50 degrees or below so at 55 degrees C they are more or less silent. I have undervolted the GPU as I was horrified by it's stock power consumption. Coming from a GTX1070 and total system power around 200w it shot up to 450w pretty much continously with the 3070 when gaming. I managed to save just over 100w of power while overclocking the vram by 600mhz, The card now boosts slightly higher while running cooler so I have gained performance and lost none yet the whole system draws a maximum of up to 344w while gaming (normally in the 275-300w range depending on the game).
I have had zero problems with this pc, no faults, no overheating, no software problems, it just works as it should. It's probably going to be as it is for a couple of years more before I upgrade anything unless a decent priced 14700k pops up in the MM. Graphics card wise I am probably going to stick for a couple of years and am going to stick with my normal £400 max. Never again will I overpay for a GPU. I may even jump ship to AMD when the time comes as I have a itch for a 32" 1440p IPS screen.
Sorry for rabbiting on, I got carried away a tad. Wifey says I do the same when I text as well. Here's a couple of pictures of the insides of the pc.
I really have to do something with those damn ARGB cables!!
Build is in my sig.
I purchased Node 304 case in 2015 and it has gone through 2 different builds - I stuck with it because I love the look of it and it fullfills most of my requirements.
My latest build is a compact, silent mid-range gaming PC that runs pretty much most modern games at high settings and at decent framerates whilst running very quiet at the same time.
Temps are very good for this build with the cpu and gpu idling around 40c and 30c and during heavy gaming load, 65c and 60c - I have the 3060Ti underclocked @ 1900Mhz/0.875v. Ambient temperature is 23c as of writing.
I was hoping to upgrade my GTX 1080 to a RTX 4060Ti but as the performance was so poor compared to last generation, I managed to pickup a 3060Ti for around £220 instead, which is a worthy upgrade whilst allowing me to use DLSS and raytracing. Hopefully this card will last me for a year or two until the RTX 5000 series comes out and pricing vs performance returns to affordable levels again.
As I am on the AM4 platform, if there comes a point when I need to upgrade my 3700X, I can just slot-in a 58003D. However as I am running a 3060Ti, my CPU should not present any bottlenecks.
https://images2.~imgbox~/57/4f/pO1pGmv4_o.jpg https://images2.~imgbox~/e3/eb/ZXlYsQno_o.jpg https://images2.~imgbox~/a5/9e/ACzfpG1S_o.jpg https://images2.~imgbox~/ae/89/lDZYpJah_o.jpg https://images2.~imgbox~/e5/d6/06Mdgo6T_o.jpg https://images2.~imgbox~/a7/dd/hSuJUFmm_o.jpg https://images2.~imgbox~/bb/4c/Z2IGHV7x_o.jpg
Heyo, who doesn't love listing their hardware lol
5950x@stock, first chip I can honestly say I won silicone lottery with because out of the box 9/16 cores run at 5Ghz + (max I ever saw was one reaching 5100, others sit at 5-5025hz).
Asus Crosshair VII X470
32GB 8Pack TeamGroup 3200CL14
Sapphire Nitro 7900XTX Pulse
1100W Silverstone Titanium PSU (can't remember the model from the top of my head!)
Acer 144Hz 1440p screen + 2 random basic 24inchers
I am honestly more than happy with my system, about 3-4 years back i replaced all the fans with Noctua's 120mm chromiums + Aquaero 6xt fan controller to manage them independly of the system and have had 0 issues (other than when the AIO pump failed lol). Can always find things to improve or what to spend money on, but with prices going up up up it's becoming quite hard to justify spending money on the one vice that i have...
Build is in my sig.
Lovely pics, thanks for sharing :) very clean and neat. GGs!
That's quite a beast you got there.
Good you got a good CPU my 5800x is also a good one boosts to 5ghz on all cores.
I think yours is 16 cores, I honestly think the 8 or 16 core chips binned better then the 6 or 12 core ones based off the reading I have done, makes sense why as well.
Thanks, and yeah it's a feelsgoodman to get a nice chip! :)
Just finished my new build after over 7 years with a 7700K/GTX1080:
ASRock B650E PG-ITX
Ryzen 7600 / Noctua NH-D9L
32GB GSkill Flare X5 DDR5 6000 CL30
2 x WD Black 2TB nvme
Asus ROG Loki 1000w Platinum PSU
RTX 3080ti Founders Edition
Dan C4-SFX case
PBO set to 85C slightly overclocked, runs 5.2ghz all cores at 110W peak with RAM on EXPO settings. 3080ti undervolted gets 1800Mhz on GPU at 300W.
I picked the ASRock ITX MB as it is passively cooled and still with a good feature set. The Asus has more, but has the weird addon modules and I didn't want their crazy chipset fan annoying me. The BIOS isn't as good as Asus, but once you find your way around the menus it's fine and I'm very happy with it.
Fast. Silent in normal use. Still quiet in gaming. Temperatures well into safe zones on all components.
More than powerful enough for 1440P gaming on my Dell 144hz monitor and literally half the physical size of my last cube case
https://i.~ibb.co~/4Kd7ZMC/20230814-100859.jpg
ASRock B650E PG-ITX
Dan C4-SFX case
More than powerful enough for 1440P gaming on my Dell 144hz monitor.
Nice system. Also really like the aesthetics of C4 case, although heard they're not the easiest to build in - how did you find it?
Absolute piece of cake to build.
As with any SFF build you have to do a bit of research to make sure everything will fit before buying components but I had no issues at all, even the Loki PSU cables were short enough to just tidy up without buying custom cables. I did buy a FE GPU to play it safe with temperatures because the case has a special exhaust port for it and I couldn't afford a lower power/cooler 4080, though if I decide to upgrade, I'll probably go for a 3rd party card and de-shroud it, just cool it with the 2x140mm intake fans instead as per the LTT review of the case.
ASRock B650E PG-ITX
Dan C4-SFX case
Your old CPU/GPU combo is the exact same one as my previous build :)
Your new 7600/3080Ti combo should last you a while but my only concern would be the 12GB vram on the 3080ti and whether that will be sufficient enough for this console generation given the recent rise in Vram requirements.
VRAM issues are a little overhyped. 12GB will be fine for 1440p and in the event a console port in 2 years time needs more, just turn down textures a little - with DLSS etc the difference will be minimal.
In any case the 3080ti is a stopgap - I wanted a 4080, but refuse to pay the current ridiculous price/performance for 40 series. Happy to wait and see what happens with 50 series pricing and buy a used 4080 if necessary. Buying AM5 means I have a long term upgrade path from both CPU and GPU if I need one.
