Gigabyte b650 aorus elite ax won’t boot if I enable EXPO
6 Oct 2004
England
Having an issue with my new build.
Everything works great, other than the fact if I enable EXPO in BIOS the machine won't boot - I have to reset CMOS (hold metal across the 2 jumpers for 5\~ seconds) to reset the BIOS.
The B650 Aorus Elite AX is flashed to BIOS version F8c. The ram is DDR5 6000MHZ corsair ram, I checked the website before purchasing and it's compatible.
This is paired with a Ryzen 7 7800X3D
Any suggestions?
Does it set the dram voltage correctly when you enable EXPO?
If im honest I would have ASSUMED it did, i'm guessing not?
This help?
I'm not familiar with that bios, but it looks like it is running at 1.1 (I'd go into advanced voltage settings), when Corsair rate the memory for 1.35? Though, the profile clearly says "1.350" so it is being picked up somewhere.
Yep DDR-VDD change to 1.35, same with DDR-VDDQ ( can be less but keep the same for testing )
DDR-VPP leave at Auto ( 1.8 is correct )
Ok I think that worked! Windows task manager > performance > memory is now showing Speed: 6000MHz
