OPENRGB wont detect 4090 TUF OC to turn off LED
30 Jul 2007
Its detecting my asus X670e fine and able to turn off leds.
The 4090 TUF OC is on supported device list but is not detected by scan.
ive tried running as administrator.
any ideas?
i really dont want to install armory crate if it can be avoided.
thank you.
FWIW i installed the nvidia driver from nvidia website and device just shows as NVIDIA 4090 not ASUS 4090...., if thats important. AFAIK the asus driver download points to a generic nvidia driver.
Do you have Microsoft Visual 2019 C++ runtime installed? The GitHub page says it's a requirement:
Also, maybe try the latest unstable release?
Genius, experimental version worked...thanks
EDIT
great bit of software dont even need to launch it to enforce the off profile...the devices seem to remember their setting.
