4k player time
15 Sep 2009
Birmingham
I'm looking at buying a 4k disc player
I've not had a dvd player of any kind for a while but want to jump to the 4k player for things such as Lord of the Rings and Harry Potter
I've been thinking about either the Panasonic DP-UB159, Sony UBP-X700 or Sony UBP-X800M2
It'll be connected to my LG C1 OLED TV
I was after the LG player but that seems to have been discontinued
I wouldn't recommend any of players you have listed @markwilliams82.
The Panasonic does not output Dolby Vision and both Sony's do not output Dolby Vision unless you go into the menu each time and select it.
As @Simmz suggested, the best player bang for buck is the Panasonic DP-UB820EB
Reviews look really good thanks.
Quick question, if I plugged a USB HDD or connected it to my network, would it play mkv files?
Apparently they will from the rear USB, you may have to use a different audio track these ones are supported AAC, PCM, Vorbis and FLAC. I never use MKV's so don't just rely on my info ;)
For me while I have my own media library. It's really only my most favourite movies I'm going to get on disk. Because I don't want to be faffing about with subtitles and audio tracks. Also many of my favourites aren't on the streaming services or downloads are often in lesser quality. Also it saves the time and hardware needed to store it digitally.
