 - 11 Jun 2012
Hi all,
Been having a nightmare with my new build.
I made another thread a while back trying to figure out issues with this build and it turned out a m.2 was defective. Now though I'm back to thinking the mobo is the issue. What I've seen is that when playing games and/or downloading large quantities of data my ethernet device dies. This then leads to really weird inconsistent issues including:
When the ethernet drops the machine stutters pretty intensely and LatencyMon complains about HDAudBus, ndis, and dxgkrnl primarily
Event viewer shows the ethernet device has encounters some error and then thinks the device has been removed.
Things I've tried:
Any help greatly appreciated
- 5800X3D
 - ROG STRIX B550-F
 - RX 7900 XT
 - 2x16gb Corsair DDR4 Vengeance RGB PRO SL Black
 - SK hynix Plat P41 2TB m.2
 - be quiet! Straight Power 11 Platinum 850 Watt 80+ Platinum
- Unable to shut down or restart, it sits on the Restarting... screen indefinitely, have to hold down the power button.
 - Unable to boot up until switching off at mains for a few minutes
 - BIOS errors on start up including:
- no keyboard found
 - PCI Vendor and Device IDs do not match!
 - USB overcharge detected
 - hard disk read failures
 - Booting up and showing mobo splash screen but never progressing
 - Powering on but black screen, no peripherals coming online
Things I've tried:
- SFC, DISM, chkdsk, SFC found some corrupted stuff on the first run but claimed to clean it up and it didn't help
 - Disabled all low power / sleep options
 - Installed a PCI-e NIC, disabled onboard LAN via BIOS, made things worse if anything
 - Cleared CMOS
 - One of my SSDs was plugged into the 5th sata port as GPU covered the others, moved it to the 2nd
 - Reseated everything
 - Numerous driver tweaks, reinstalls, rollbacks etc
