- 14 Jul 2005
- Birmingham
Will soon be buying the wardrobes, Ikea PAX.
We have skirting boards in the room currently.
1. Cut and remove skirting from behind where the wardrobes will be so that the carcass sits flat to the wall.
2. Fit a batten at high level the same depth as the skirting which the top brackets will affix to.
3. Cut out a notch on the carcass itself so that it goes over the skirting board and sits flat to the wall.
Which option has anyone else done with PAX?
They aren't 'proper' fitted wardrobes, so Im a bit reluctant to start chopping away the skirting. Option 2 means there will be a gap between wardrobe and wall, which over time will get dusty and be a spider hidey place. Ideally I'd want to do option 3, but I don't know whether the design of the wardrobe carcass easily allows a bit to be trimmed off it?
Any PAX owners?
Any PAX owners?
