Command to find empty directories
6 Sep 2016
Is there a way of displaying directories that have no files within them? Or under <100mb or so. I don't want them deleted, just shown as a list.
I installed foldersize (it's a windows that opens to the right of windows explorer) but it's not working for all directories, some which are full are showing 0kb, yet others which are empty show 0kb
Could the reason it (foldersize) is showing some full folders as 0kb be down to a permissions thing, are you running it with admin rights?
Not sure it fits the bill but you could use this powershell snippet...
Get-ChildItem 'C:' -Recurse | Where-Object { $_.PSIsContainer -eq $True } | Where-Object { $_.GetFileSystemInfos().Count -eq 0 } | Select-Object FullName
Could try this free software.
It will list all the empty folders and then give you the option to delete them all or some etc
Just because a directory appears empty doesn't mean there aren't hidden files or subdirectories.
I recommend Treesize Pro and Wiztree.
