is 1000watt psu necessary or essential ?
1 Dec 2017
I have a 750watt fully modular psu my specs are 3060ti, i9 -9900kf, 32gb ddr4 3600mhz ram, Home system runs off ssd and is liquid cooled 30-40 degrees c idle 50-60 under demand . Pc runs well although have been running into various issues over the past year which i believe could be the psu per output demands.
i have run a osct stress test on cpu which passed all tests. memory passes all tests , but the psu crashes the system everytime.
i have checked the crash dumps logs and there is a lot of kernel power 41 logs i have noticed this happens a lot on AAA games with high gpu demands but it flags as a kernel power 41 ID,
i have lowered the game specs on an individual basis but im almost sure this is something to do with the psu. temperatures are good, cpu never runs higher than 30-40% unless installing or running full system scan gpu hits 100% useage, and is not overclocked , besides xmp and gameboost active in the bios this is with this current performance.
id have thought 750watts was ample for a fairly high spec system but 1000 seems to be becoming a requirement for higher end computers
You won't need anything close to 1000 watt to run that system - I've got a 3070FE with a relatively power hungry (by modern standards) Xeon on a 860 watt PSU and most of the time it is barely using the PSU at 50% capacity under heavy loads.
This can be an indicator of a faulty PSU, but all it is saying is that the computer shut down or restarted unexpectedly.
As tamzzy asked, what model is that and how old?
What issues?
I believe Gameboost is automated overclocking and strictly speaking, so is XMP, so I'd turn them both off.
You don't even need 750 for your PC, 1000 would be way overkill.
I'm using a 750w PSU with a 13900k and a 4090
If your PSU isn't coping with your system then it's a faulty PSU, nothing to do with the wattage
