Don
- 20 Oct 2002
- Oxfordshire / Bucks
Quest pro 2 is in development
will be going against the Apple Pro
If it's got localised local dimming colour me interested![]()
How about localised local location dimming![]()
oof harsh comments on the pro...... its not that i disagree with the individual points, so i guess IF you want an AR device he is correct.............. and if you just want to do mobile gaming then yes i was a hell of an over priced quest 2 and the upgrades didnt warrant the price.Quest pro 2 is in development
I was looking into this. Apparently you'll need the sort that you use to illuminate gardens that run on 12v, and potentially two of them. The small IR illuminators don't provide enough light.
You need ones that you can put on a shelf or wall mount as attaching to the headset isn't good enough as the controllers need lots of light even when the headset can't see them.
I'm sure there'll still be some dim locals around.
Cookie already has garden lights apparently and it does not work for him
I told him you get a proper bulb
Also boo booed putting it in this thread thought it was the pro one!!
