Insulating timber frame walls with external tiles
28 Dec 2017
Beds
So on purchasing our first house, we discovered the exterior walls are timber framed. Not only that but very flimsy - the entire wall is effectively a lightweight stud wall nailed to the side of the building. It's then got about an inch of fibreglass type fluffy insulation and is skinned with felt and has tiles hung on the outside.
So these walls are about 2 inches thick, literally, and mostly air gap. They also wobble and flex!
We have been preparing to improve insulation by building out the studwork internally and fitting PIR board to the depth of the new studs. This will leave the existing air gap in place for, hopefully, the same amount of ventilation as the walls had before. The timbers don't seem to be rotten or damp at all, so it seems a reasonably safe starting point.
What has occurred to me now we get into the job though is that the temperature gradient through the wall is going to be stretched and moved. Right now, presumably the insulation on the cold side of the timber is relatively warm and so would the felt be. With 75-100mm added PIR, that air gap and felt layer might become considerably colder. I don't know that there is any real ventilation at all. So my concern is that we would be risking interstitial condensation on the original timbers.
Ok - so perhaps mitigation number 1: add a vapour barrier over the insulation before plasterboarding, on the warm side of the new timbers. Should keep moisture from the living space out of the wall. Complication number 2: the timber frame making up the exterior wall is continuous between floors. So if I insulate the floor level walls on one floor, some of the original timbers exist blow floor level, and also at ceiling height in the room below. Diagrams will probably clarify this... let me see if I have some to hand.
So now I have two concerns: 1, will moisture be an issue in the existing walls, and 2, if we moisture barrier the room walls, is there then a huge vapour leak through the floor gaps?
I was fully prepped to do this job (albeit one room at a time over time). I know I could do it as best I can and seal the walls up, and it would seem fine for years. But with no way to inspect this framework later, it's not very fair to just do the work and FU to the next owner (or retirement age Benski).
Some pics:
You want the vapour barrier on the warm side. Had similar here and I put PIR board into those voids then battened out another 50mm filled this too and then foil taped everything as the vapor barrier, then plaster board on top.
Haha no it isn't the right link.
So my house is slightly different construction I have single block tile hung first floor but normal cavity ground floor.(but I had one wall fhat was like yours that was just wood framed) I went for the best I could without completely ripping my whole house apart which was batten and 50mm pir with foil tape as the barrier. I then took up the floor boards on edge of room and put rock wool in between the joists to minimise any draughts where the floors met.
It seems to have done the job, last winter I only had 2 rads installed and barely had them on, all rooms went from being freezing cold to 100% comfy with no reoccurrence of the mould I was having in the top corner of most walls. Also used about a 3rd less gas last winter to keep the house about 1.5c warmer according to my sensors.
Does the roof have a dip in the middle or is it an optical illusion caused by the tree branches.
I get that the house to the right in the photo is higher than the others but their rooflines look
at a consistent angle while the middle one seems to dip in the middle.
That looks like some bad Google Street view stitching but I'll have a look shortly!
The roof itself has been replaced since those pics too - right before we bought it. The ceiling joists are a bit wavy between rows but I think it's not sagging.
Here's the roofline as of Dec 2021: does look a bit curved but not awful.
Insulated plasterboard? Maybe an option if you have the room.
AFAIK you need to treat it like a cold roof, so insulate on the internal surface and maintain the air gap on the outer face.
I'm definitely bringing the surface into the room, don't mind losing a few cm. But was going to do it with stud frame to reinforce the **** walls, so they don't crack at the edges.
My analysis of the wall is it's built like a warm roof actually - plasterboard then timber then air then insulation then felt then tiles.
The actual flat roof is a warm roof and the installer said not to add insulation or close the air gap too. Wonder if he'd care to comment on my walls :D
If it was me I would go cellotex and tyvek, the brands may vary but the pu foam and breathable membrane would remain.
Crosswall construction by the looks of it - a lot of lenders won’t lend on crosswall. Hope it was identified as such when you bought it? I could be wrong but visually and based on your comments it certainly sounds like it
Definitely cross wall construction, and a pretty slapdash example too. Pretty sure this came up in the Level 3 survey because I remember researching the term for ages before we completed. I believe some lenders consider it traditional construction so long as the intermediate/party walls are brick.
In reality there's only about 10% brick on the exterior, and everything internal is very crumbly breeze block :eek:
It's such a cheap house but as a home it's grand. Once I get these issues reasonably mitigated, and brick up the porch/garage, I'll be pretty happy. Rewire was needed as one socket per room only. Roof is brand new. Not much else to complain about, touch wood.
What you say is true but Barclays for example, whilst accepting of crosswall as a rule, will, as you say, only lend provided there is a masonry party wall AND sufficiently insulated timber front elevations which, traditionally they are not.
With this in mind, your plan to insulate the front elevation is probably a very wise one
