Hi
I have an MSI MAG Z790 DDR5 motherboard and a Zotac 4090 all mounted in a LianLi Lancool III case. After connecting everything up, I appeared to be getting no power to the GPU. The green LED near the 12v plug was on so everything appeared fine there with both the Corsair 12vhpr cable and the adapter that came with the card but the system would not detect the GPU. I could get a display via the CPU (13700K).
After a bit of troubleshooting, it appears that the GPU has a very poor connection with the PCI slot. Eventually I found a stable position by booting to the bios and wiggling it around until the LEDs came on and were stable. Even now I'm not confident it will continue to work if the PC is moved. I did a bit of cable management and it stopped working again - took some time to get it back. I do have my old 2080Ti I could try, but now the GPU is working again (and I'm sure I'm not doing the card or the slot any good with the pressure it takes to get it to work) I'm reluctant to take the new card out again. As I'm using a Lancool 3, I've no option to try a vertical mount with a riser.
Anyone else seen this before, or have I just got unlucky with either the motherboard or the card? My concern is with only 1 of the 3 PCI backplate screws plugged in, and no GPU support, its not going to stay put forever!
