AX90 case, by Antec.
8 Sep 2003
150 yds from OcUK
Hi guys.
Check out this cool build.
Antec AX90 Case - https://antec.com/product/case/ax90
The PSU cable extensions are new from Antec - https://antec.com/documents/product...xtension Cable RTX 30 Series 6Pack_230111.pdf
AIO Cooler is the Antec Vortex. https://antec.com/product/cooling/vortex360-argb
1 Sep 2003
Redcar
Should probably disclose its sponsored, even if it's just they employ you etc. Otherwise it gives the impression someone thinks it's a case genuinely above and beyond with no other external factors. Same as if someone ever got a piece of tech for free etc, its good practice to state it. :)
5 Mar 2017
Cambridge
G500A, 5000D airflow,
Hard to come up with a new design, I know, but there’s plenty of missing features from cases already available that carry on neglected on “new” released cases.
The NV7, for example, totally useless USB ports at the bottom. Case is too big and heavy to expect everyone to have them on the desk.
H9 Flow, a bit more clearance on the top would be an almost perfect case. As it is, top exhaust is either impossible (Arctic AIO + T30) or fans will be noisy, or even interfere, because are very close to vertical cable hiding bar.
Similar issue with the 5000D.
G500A could get rid of the silly PSU cut out.
OP
8 Sep 2003
150 yds from OcUK
I used to have "Antec-Rep" as my title on this forums, but OcUK forum gods decided to remove that from my account.
ryu
ryu
25 Oct 2002
Have they also placed a 150 yard restraining order to stop you showing up at the door and bartering too? :D
