Ukraine Invasion - Please do not post videos showing attacks/similar
Status
Not open for further replies.
Funny, Elon has a big mouth on Twitter but in public he just wants to run away like a baby
Not being funny, but would you want to aggravate the guy who murders people by throwing chemical weapons around in a busy town? The man just wants to give rural areas fast internet, not provide ordinance to wind up the worlds biggest head the balls!
As somebody mentioned a few pages back, Russia are restarting T-80 production, but what wasn't really known until now is why.
At first glance, committing scarce resources to restarting a production line that shut down 30+ years ago when you don't even have the parts on hand sounds ludicrous. Especially when you're still making T-72 and T-90 tanks, but there is method to the madness.
If they tried to increase T-72 or T-90 production they would have to create a whole new production line for a tank (I say a tank as the T-90 is itself a T-72 variant, renamed for marketing purposes) they're already struggling to get the parts for, but because the T-80 is an upgraded version of the Ukrainian T-64, it shares less parts than the T-72 and T-90. By restarting the T-80 line they open up alternative avenues for parts and it means they can salvage parts from T-64/80 tanks in storage that are unrepairable to fill in the short fall. Obviously the old line will not be reactivated overnight.
Another reason behind it is that while we never really hear of Russian successes in this war, they do occasionally have them. And one of their big-er successes thus far has been the introduction of the BMPT "Terminator", which is essentially a modern successor to the ZSU-23-4 (which is still in service today with many ex-Soviet states/allies, inc Ukraine). They have now upgraded this design into the BMPT-72 "Terminator 2" which uses a T-72 hull. This means that every new or modernized T-72/T-90 that rolls out the factory could have been a BMPT-72, and right now they want them more than they want extra T-72/T-90 tanks.
For anyone who hasn't seen one of these, image a T-72 with the turret replaced by four NLAWs and a dual autocannon, plus in uncharacteristic Russian fashion the optics to make it usable. So no harder to destroy than a T-72/T-90, but much more lethal on a modern battlefield.
So yeah, we knew that was happening but now we also know why.
Superstructure is ripperino'd, hull looks alright though
And what did it look like after the explosion?
I've not seen many reports, outside a couple of individual instances, where the BMPTs have performed - months back they ended up pulling the initial ~13 or however many it was back to defensive use after failings in their intended role, though there is at least one recent video of one being damaged in frontline use.
I suspect any T-80 produced now will be using a lot of off the shelf parts and probably be simplified quite a lot from older ones - probably very similar to a basic T-72, be interesting to see what they are using engine wise - doesn't look like Klimov still produce the original turbines.
Main gun(s) on BMPT72 arnt stabilised, and are mounted way to close (conformant recoil harmonics) - eg, both guns reinforce each other for bouncing after shots fired. This massively reduces accuracy :
If it was in drydock the fire could have damaged the hull structure much worse than if it was in the water due to heat, IIRC even in the water heat damage from a bad fire can write off a ship (or at least make it much more expensive), out of the water you're probably going to have a much worse issue because you don't have the sea as a heatsink.
At the very least if they want it to be usable again and not just potentially waste a fortune getting it "ready" only for it to end up straight back in the docks they're potentially going to have to do a lot of testing before they start any other works on it, and given Russia from memory has a shortage of naval repair docks, especially outside of missile range that's going to be an issue. I suspect they're not getting that boat back up and running under it's own power or at least in any fighting shape for a very long time (even before they invaded Ukraine they struggled).
Thought I'd have a quick looksie and see what they were
The BMPT-72 (Terminator 2) can be motorized with two types of engine: the original 850 hp B84MC or the new 1,000 hp. B92C2 powerplant. Both are 12-cylinder V-type multi-fuel, liquid-cooled Diesel engines. The B92C2 is a turbo supercharger that offers higher power and efficiency. The engine is coupled to a hydraulically assisted transmission with 7 forward and 1 reverse gears. The BMPT-72 also uses an auxiliary power unit to extend mission endurance and run all systems during a silent watch. The BMPT-72 is able to reach a maximum road speed of 60 km/h with a maximum cursing range of 500 km.
It's a nice touch. Perfect for lamenting Putin's lunacy during a high-speed retreat. Unless that's a military term in which case I can only apologise for my ignorance :p
One problem with the BMPT is the slow reverse speed - a vehicle like that with needs to be highly manoeuvrable, especially to make use of the auto-lock and engage functionality.
Status
