Posted in a few threads across this sub forum and Networking but it's almost crunch time and I want to make sure I've got things right. We're weeks away from getting the keys to our first house
(1930s built) and I'm in charge of sorting out our network and CCTV needs. I've had a network cable installer/low voltage quote me £125 per RJ45 run (not bad) but have him on hold for now as we need a few jobs doing by an electrician who can also do cable runs.
Equipment:
As you can see in my original diagram, it's just the one AP for the ground floor which will likely not be good for covering the kitchen and garden. As for the APs - I think I have 3 WiFi5 Unifi APs including 1 LR. These will do for now and when I can be bothered, will swap them out for WiFi 6 versions. I'm meeting the electrician this Friday to have a look at the house, he's just a sparky so won't be terminating but that's something I'd like to do myself.
Questions:
Thanks for your time and please let me know if I a missing something/not considered.
*Front of the house
(1930s built) and I'm in charge of sorting out our network and CCTV needs. I've had a network cable installer/low voltage quote me £125 per RJ45 run (not bad) but have him on hold for now as we need a few jobs doing by an electrician who can also do cable runs.Equipment:
- UBIQUITI UniFi Dream Machine SE
- 2 x Unifi G4 Bullet cameras
- G4 doorbell
- WD Purple Pro 8TB Surveillance 3.5"
- Cat6 UTP LSOH Solid Core Cable (either x100m or x300m)
- Cat6 patch panel cables
- Patch panel
- Network cabinet
- Back boxes (for TV/HTPC run and possibly my office)
- Terminating equipment
- Edit - Heath Zenith 35/M Wired Door Chime (compatible with the G4 doorbell)
- I'd previously thought of cabling every room (and having at least 2 cables per run) but revised the plan to:
- 2 x cable runs (one for each AP placed on the ground floor and 1st floor hallway ceilings)
- 1 run to exterior rear of house for PoE CCTV
- 1 run to exterior front of house for PoE CCTV
- Same again for the Unifi doorbell
- 1 run for the TV/HTPC/media centre (probably 4 cables)
- Worried the kitchen and garden don't have enough coverage so might do an AP/run on the ceiling of the kitchen or for an outdoor AP
- Perhaps 1 run (2-3 cables) with plenty of excess to the attic for a future extension
- I may add a single run for the back bedroom which will be the spare room and my office so would have another back box added here
- Going to do a run from the front living room where the ONT will be to the network cabinet
Questions:
- What's the difference between a patch panel vs keystone patch panel/should I care?
- Unsure how much Cat6 cabling I need - it's either in 100m or 300m rolls
- Will one type of roll of the aforementioned Cat6 cable be enough? Or will I need different types for the CCTV?
- Is my attic run worthwhile or should I just have some runs done when/if we do the loft conversion (will be many years)
- What's a good height for the CCTV cameras (not too high so you can see faces) - internet seems to think ~2.5m*
- Would you still do e.g. 2 cables per run for the APs on the ceiling? As I'm unsure if we're going down the 'through the ceiling route' or the more likely 'neat trunking' route
*Front of the house
