 - 29 Jun 2013
This is all about silence, not about overclocking, powerful GPUs and running games. The computer cases are all of a silent design with low noise power supplies. There is no problem with using i7 processors in these cases, I've been doing this since the first i7s were made.
I just upgraded my wife's computer and it has just one problem. The Corsair H60 AIO cooler I have makes a noise. I don't care so much about fan noise, I expect a whoosh if the machine works hard. But this is a continuous whine/tone from the pump. It is quiet and I expect within its design spec, most people would ignore it, but I have good hearing and it is like having tinnitus. If I could attach a file I would let you listen to 10 seconds of it.
My computer, also in the same room, has an older similar cooler, bought from Overclockers in 2018, an Asetek 120mm 570LC, and its pump is truly silent. I have a second machine with the same cooler, also silent. I wrongly assumed that all these pumps were silent. I want to stick with water cooling, it has worked so well for me for the last 5 years.
I don't care about the lights, the computer cases have solid sides and top, so no light escapes.
So I want to buy an AIO cooler for an Intel 1700 socket with a single 120mm fan that has a silent pump. Cost is not an issue.
I've seen a brand called "be quiet" which might have a silent pump? but their only single fan products are preorder.
I need to fix this by the end of next week when she gets back!
All suggestions welcome.
