Yeah, it shows it but only gives the option for booking inYup, I believe the battery can be done on a post in thing.
13 Pro Max?Decemeber 31st 2021 - iPhone 14 Pro Max
That's what I meant to say!13 Pro Max?
My iPhone 12 is just over 2 years old and is on 87%iPhone 12, just under 2 years old, battery is on 87%
When would you guys replace your battery (or phone)? Mine is down to 76% and the phone reports that as ‘significantly degraded’.
I do sometimes charge it twice a day if I’m using it a lot. Just checked GiffGaff and they don’t offer eSIM just yet (will be later in the year). May wait for that then change.Right now.
I’d change it if I couldn’t get a full day out of it. Apple basically say less than 80%
iPhone 12 Pro @ 94%. Bought on 16 Oct 2020.
I think so too. I think there was probably a batch of bad batteries used on some iPhones on the 14 pro last year. Can’t prove it or anything but just my opinion. Mine is currently at 87% after a year. Never had a phone drain so quick either.Honestly think there is something wrong with some iPhone 14 Pro batteries, I got mine a month after my sister, both near launch, so mine was only 11 months old and before I swapped to my 15 Pro mine was at 88% and my sisters is still at 96%.
