- 22 Feb 2014
I am just testing a system for someone.
X570 board, 5950x, Asus RTX4090
Corsair HS1000i
however, they haven't supplied me with enough PCI-E power cables, so I decided to use a spare PSU to test.
corsair HX1000i installed inside the case, connected to everything on the board, and 2 x PCI-E connectors on the supplied adapter for the GPU
secondary PSU connected to the 2 remaining PCI-E power connectors.
as soon as I turn on the secondary PSU all of the fans lit up and started spinning, and the motherboard diagnostic LED displayed some numbers.
I then turned on the system, it booted fine and ran superposition, score was as expected.
I then shutdown the machine, turned off then disconnected the spare power supply, went to turn off the PSU installed in the case and it was already off!!
just to check I wasn't going crazy I tested it again and the system will power up with the installed PSU switched off when the external PSU is connected ONLY to 2 of the GPU PCI-E connectors.
I then ran another benchmark, this time with both PSUs switched on and halfway through the system just powered off.
I then ran a 3rd benchmark with the spare power supply connected to all 4 of the PCI-E power connectors and it ran the benchmark just fine (albeit a slightly lower score)
NOTE: this time the fans did not light up when I turned on the external PSU, only when i pressed the power switch to boot the system.
I have worked on PCs for 20 odd years and never seen this happen before.
Corsair HS1000i
