If you want a quick fix, remove the lightshade and buy the most powerful daylight colour temperature bayonet fitting bulb you can find, of which is still LED. Something like 6000k perhaps of around 20W or so? It will probably look ugly though and will be some Chinese thing which may burn your house down.
If you don't mind DIY or getting a sparky in, you could get them to replace the ceiling rose with some kind of GU10 strip setup, like you tend to find in kitchens. The ones where you might get say 4, 5 or even 6 GU10 LED bulb holders in a row on a metal strip which can be aimed where you want.
Alternative would be an LED surface mounted strip light. These are cheap from places like TLC and have very high output. You could get a little 3 or 4 foot one. Would be a bit imposing and might give a more industrial feel to your office. Up to you if you feel that would look rubbish.
Or the best solution which would look the best and be functional and is also the most expensive, would be to do away with the ceiling rose and get as many LED downlights - preferably dimmable - to suit the room. You could have as many as you want. You'd need the ceiling to be flush style and not lumpy artex, so that may have to be factored into the cost if not already the case.
EDIT: Also paint walls and ceiling chalk white for uber reflective properties.
