Is anyone else finding that their weather complications are often failing to load with the new release? Often I’ll glance at my wrist and the complications are blank. Tapping through, the weather app launches and shows the information correctly.
Yes, it's a bug. You can sometimes make it show again for a while by playing with the settings but it's a proper bug. Make sure you report it https://www.apple.com/feedback/ and hopefully it'll get fixed quickly.Is anyone else finding that their weather complications are often failing to load with the new release? Often I’ll glance at my wrist and the complications are blank. Tapping through, the weather app launches and shows the information correctly.
10.0.2 out for the 9 and Ultra 2.
It's made no difference to me and the suggestions they make just kick it in for a short while and then it fails again. It needs a proper fix, not a workaround.
It won't last.
I only use the large centre one but it’s been perfect using the 17.1 betas.Hopefully it fixes the weather complication.
