Help windows 11 won't install on new am5 system
22 Oct 2004
Just built it looks fine in bios. I plug usb in with windows 11 and it says my system don't meet requirements.
7800x3d
Asus b650x tug matx
M.2 Samsung 2t
7900xtx
fTPM screen: you have it enabled so that looks fine, but not sure the erase should be enabled. Was the erase already enabled? If so, I'd leave it be.
Fast boot: you might want to disable that until the system is working 100%.
Secure boot: what options exist other than "standard" and "other OS"?
Launch CSM: I should think you need to set this to disabled.
Secure boot has custom and standard.
Os type says other OS or windows uefi mode
Omg it was the fast boot I turned it off and it worked.
Thankyou so much I really appreciate this.
Installing windows now.
Thought I ran into more problems not being able to install windows 11 on a clean build on WiFi. Found a way to say no internet carry on installing. Worked then I'll luckily had the WiFi drivers on a usb.
So far so good, fingers crossed, loads of updates to put on now.
